Suspension Service Observations/Thoughts 32rls
Turfengineer
I just finished servicing the Cre 3000 suspension and wheel bearings on my ‘22 32RLS.
This was the first time using the EZ-Lube system, and I was actually suprised how well it worked. I do like being able to fully inspect bearing and brakes by manually repacking the bearings, so I likely won’t use it every year.
The Cre 3000 was a mess, which I did have a gut feeling it would be. Of the 14 wet bolts, I had 5 that would not take grease and required disassembly and cleaning. I had one leaf spring that had the leaf retaining clip (?) dislocated. I was able to move it back into place, but I will likely try to find a replacement because I don’t think this will remain in place.
Overall, this was the deepest dive that I’ve done on this trailers running gear. I’m glad I did because it provides a little price of mind. Now I’m off to replace the broken microwave and finish converting the dinette into a dog Crete/seating area. Can’t wait to get on the road for a few NP trips this year.
I was having issues with my wet bolts and cree 3000 taking grease when I bought mine back in 2023. I found clocking the bolts/grease holes to 9 or 3 o’clock worked for me.
UFF, thanks for the info. I have problems with one zerk fitting on my 2025 with CRE3000. Was surprised at how much grease that I put into the rest. The all indicated a little grease coming out the backside after a few pumps on the grease but this one on the right rear. Will try and do as you suggested and rotate it to 9 or 3 and see.
Thanks again!
Happy Glamping!! :cool:
  • Like
Reactions: UFF
Turfengineer, just curious, Is this the first time that you have repacked the bearings? I used to repack bearings with my Dad and it is really not a difficult job. Hardest part is getting the wheel assembly and hub off. Just got mine Sep 2025 so have at least a year before that is done. Figure every 2 years for that from what I have read.
Happy Glamping!!:cool:
Turfengineer
This was the first time I used the EZ-Lube system as I typically pack them the old fashion way. We bought our ‘22 new, but in ‘23. I serviced the bearings in 2024 by removing the hubs.
