Stainless Steel water inlet upgrade
jagibson58
Has anyone installed a stainless steel water inlet? Looks interesting. Pro Rver is one supplier of the part.
Should be an easy job. Can you share a link of the one you want to use?
"If it ain't broke, fix it" is my motto. 🙃 But in this case... I don't fool with the threaded connection anymore. I attached a whip and a quick disconnect to it and leave that connected to the inlet. The whip goes outside to my filter. Another whip for for black tank rinse. Note cheap meters for knowing how much water I put in the tank(s).
Chaseweston
We have a Valor so it has the Flair-it manifold system instead of a nautilus but I just have brass 90's with quick connects on them for the inlet and flush ports. Only threading on is at the water source for the splitter/regulator setup.
Short 4' length of hose connects inlet to softener that is placed under unit. Our clearsource filters are hard plumbed in and fed from the water inlet so any water coming in, either straight to fixtures or filling the fresh tank, passes through the filters. I don't love this as the water sitting in the tank is not re-filtered before fixtures but it hasn't given us any issues and we were more often on city water when I installed it.
I do about the same. Connect ONCE to the plastic inlets with brass 90 degree and meter off that...with quick disconnect. You see the Black tank rinse on the right. I have that come out the door vs down the opening. I only rinse black tank while I am there, so I don't need the door to close.
