Sound bar options
KCAlis
Has anyone installed a soundbar below the TV and above the “fireplace mantle” in a Paradigm with the hidden pantry?
I’m ready to upgrade from the JBL squawk box. Would be great if there is a 12 volt option for the bar so I could utilize the existing feed and not have to find a way to get 120 to it.
Any chance you have a 12 volt circuit that would be robust enough to power a small inverter that would be rated to power the future sound bar?
Just kind of thinking out loud. You may not have heavy enough wire to handle the amps.
KCAlis
I’m getting ready to pull the fireplace for pre-winter cleaning. Just the opportunity to check on 120 in the pantry door. I had thought about the TV receptacle but knew it was in the steel box the TV is mounted in. Thanks again.
