Solar/Inverter/Battery Install in an Avenue 32RLS
Finished my Solar/Inverter/Battery install in our 2022 Avenue 32RLS.
-Added 3 more Renogy 320w panels to the one that came with the unit, for a total of 4. Ran them 2s2p
-Abandoned the OEM roof penetration for the 1.5" chase that runs roof to basement for solar wiring
-Victron 150/100 MPPT Solar Controller
-Victron MultiPlus-II 3000kVA 2x120v
-Victron Lynx Distributor
-Victron 500A SmartShunt
-2 BB GC3 Batteries
-Victron Cerbo GX
-Victron GX Touch 50
Install took a total of about 60 hours, spread out over 4 weekends. This did not include planning the layout and research time. I took the Solar Install class at the NRVTA that helped immensely, mostly by gaining the confidence of having participated in doing it myself once. Well worth it when comparing class cost to paying for labor to install (figuring my labor is basically free, of course). Also, have the added benefit of knowing exactly how it's all hooked together, and where to look for issues if there are problems.
3B7A70D1-A44D-48F0-8366-46227369CF77_1_105_c.jpeg5ECE68B7-916A-41F0-9B68-0F73064FE523_1_105_c.jpeg1A790ED4-7A62-4AC3-BD74-9C5E4CDE8FDB_1_105_c.jpeg
Ben and Kathy
-2 BB GC3 Batteries
-Victron Cerbo GX
Great work. It took me about 25 hours on the roof just for the 6 panels I installed. I Also abandon the original solar prep. The box gave me room for a roof breaker (circuit cutoff), and individual fuses for each three 2x in series arrays.
What is the thermostat?
Shelly S
-2 BB GC3 Batteries
-Victron Cerbo GX
View attachment 1406View attachment 1407View attachment 1408
Corncrib your note says you abandon the 1.5” pipe from factory. Did you install a new chase for your wiring? Also, what is the brand of bus bar in your box?
No. I used the 1.5“ pipe, rather than the OEM roof penetration.
Bus bar was from Amazon:
DAIERTEK Bus Bar Terminal Block 4 x 5/16" (M8) Terminal Stud, 6 x #8 (M4) Screw Terminal Positive & Ground Power Distribution Block with Cover Marine Battery Bus Bar 12V - 48V for Automotive Car Boat https://a.co/d/b3IlveY
Since this post, everything is working as expected. Stayed at a Harvest Host. Ran furnace at 64 deg, 2 hrs of TV, with sound bar and SW, charged electronic devices, made coffee, in addition to lights, 12v fridge, slides, leveling. Woke up next morning with 80% battery remaining. On rainy day, we were back to 100% by noon. Pretty happy with that.
However, I’ve developed a Touch50 screen issue. Working properly, but colors have disappeared (see pic below). Could be HDM I cable related. A rerun of that is a future project.
Shelly S
Shelly S
I love Harvest Host. We have stayed at some great ones. And they were easy for us to get a big rig in and out. We have also, done a Boondockers Welcome. They are now part of Harvest Host as well
Sorry .. missed your question:
Thermostat is the MicroAir EasyTouch ... easy install, gives me remote access and monitoring ability. So far, it's working well.
SNadler11
How do you get the cabling down to the wall by the control panel(s)? I just installed an PD2000A and it has a control panel that comes with a rj45 cable but i cannot see how to get it from the front compartment on my fifthe wheel (2024 Alliance 32rls) to that spot? Any hints?
From the front compartment, I went into the basement along the ceiling to the wall next where all the wire leads from the back of the converter/charger, fuse panel, That leads up into the wall behind the toilet, which has access to the back of the side of the cabinet at the entry where the power/control switchs are. There is a considerable amount of wiring already in that space, so it's possible to follow down from behind the control panel with a fish stick to the basement. I did end up removing the wall panel behind the toilet to make it easier, and placed some fish lines in there to use for future projects.
SNadler11
Thank You!
One other question, How did you run the cable through the deviding wall between the front storage section and the basement? Simply drill a hole or is there a pathway that the wire can be run in? Is over the ceiling or through one of the propane bays an easy option?
Thanks again.......
I just drilled thru the wall between the front and basement compartment .. over toward the corner of the basement to avoid it being caught on something loading and unloading.
offacough
Finally got my As-Build drawing completed:
A year after you posted this thread, your great work is rewarded with dumb questions. :)
Your write-up is very educational, and is helping me mock-up options for an incremental build.
  • Do you have the original full-size document available?
  • Did you create this in Visio, and do you have Victron stencils that you can point me to?
  • Did you consider a 24v or 48v build? I'm curious about the efficiency and/or savings of an EasySolar-II GX.
The first purchases for a brand-new All-Access will likely be an Epoch 12V 460Ah Battery and a Honda EU3200i Generator. The inverter, solar, and DC to DC charging will likely be updated over the course of two years. I may go a different route on the battery if I do a 24v system.
offacough
I ruled out the EasySolar when I realized it’s only for 230v systems.
Still comparing pros and cons of sticking with 12v or moving to 24v.
sledz
Crazy how models change I don't have any access to the basement from the roof other than if I were to use one of the vent tubes. I have a 2024 32RLS.
