DanNJanice
Has anyone tried wiring the output of two solar controllers in parallel? There is quite a bit of buzz about this online, however, I am not convinced it would not damage the controllers or cause them not to charge correctly. It does solve the dis-similar solar panel problems and allow you to use a mix of panels without losing efficiency.
I reached out to Renogy and asked them about it.
Here is their response:
Thank you for contacting Renogy.
Please do not connect different sizes of solar panels to the same system, otherwise it will not only reduce the efficiency of solar panels but also affect the normal use of solar panels.
We also do not recommend using two controllers in parallel, which can lead to confusion in the charging data of the controllers and thus affect the normal use of the devices.
I plan to contact the other big players and see what they say.
