Slide will not open
Johnjp
My 2021 310rl kitchen slide will not open. When we arrive at our detonation the bottom of slide was out 1-2 inches. We were able to push it back flush but it will not move. Any suggestions please.
Thanks
John P
Johnjp
Thank you, We will try working on this again in the morning when we have daylight on our side and a bit more rested after a very long travel day today. Is the kitchen/tv slide a hydraulic slide or an electric slide ?
On our 2024 310 RL the kitchen and living/dining slides are hydraulic operated. You should hear a loud pump sound when operating either. If you don’t hear the pump activate when trying to extend the kitchen, then you would need to chance a electrical circuit issue.
However, you mentioned that the slide was out a few inches upon arrival. In my mind, this would support a leak in the hydraulic circuit or a by passing hydraulic cylinder or control valve.
As a work around, you might be able to turn the drive mechanism that connects the two slide arms manually with an adjustable wrench to slowly work the slide out.
Johnjp
Were you able to level the rig? Did you get the living room slide to open?
Hi thanks for all your help
Yes we finally got it out.
Thanks for all your help. We tried all the items you recommend and the slide would not move. A clerk at the Rv park recommended a mobile RV tech. He came out and within 5 minutes located the problem. The nut that holds the slide cylinder fell off and the rod dislodged from the steel plate on the slide. He replaced the nuts tightened it up and it worked.
Thanks again for your help
John
Johnjp
Here are two photos showing the detached rod from the metal plate with the hole in the center. The rod is supposed to be connected to that hole
