Slide floor thickness
BirchyBoy
What is the thickness of the dining room slide in a 2021 310RL? I’m tired of the screw holding the love seat down popping out because of the angle. I want to get some shorter screws that can be driven straight down without penetrating.
Don't have our 340RL yet, so this is a simple guess. Can you pull back the flap on the door slide slide and then find the floor thickness?
kmac7800
I was told when I replaced our love seat that it was 3/4" plywood. I could not find philips head screws that were 1/2" or even 5/8" at Lowes or Home Depot. They are all square head.
Good luck and have fun!
//KMac
BirchyBoy
I measured it to be just over 3/4”. The love seat has a 1/2” gap between the frame and the floor, so I bought some 1/4”x1” lag bolts. I want to use a ratchet not try and shoehorn a driver down there.
Grassjohn
On a previous camper, I used 1/4 inch flat head bolts and counter-sunk the heads up through the slide room floor from the outside. This setup held a pedestal kitchen table firmly to the floor.
