yep confirmed. that is what we have here. I have never seen one of those before or heard of that but now I have been educated. thanks everyone for their input
Me either and exactly the reason why I really enjoy forums like this.
Edit:
Actually really simple design. This is what AI says about it.
A
waterless P-trap, also known as a
dry trap, works differently than a traditional water-filled P-trap. Instead of relying on a standing pool of water to block sewer gases, a waterless P-trap uses a
mechanical or physical barrier (such as a membrane or a one-way valve) to prevent sewer gases from backing up into the living space.
How a Waterless P-Trap Works
There are a few designs, but most fall into one of these categories:
- Mechanical Sealing Mechanism (e.g., HepvO valve):
- Uses a silicone rubber membrane or flap that opens under water flow pressure and seals shut when flow stops.
- The membrane prevents gases, pests, and odors from traveling back up the pipe.
- Ball or Float Valves:
- A lightweight ball sits in the trap body and seals the drain unless displaced by water flow.
- Flexible diaphragm or self-sealing valve:
- Acts like a one-way check valve; opens to let wastewater pass, then closes to block air/gas return.
Advantages
- No risk of trap seal evaporation (common in infrequently used fixtures).
- Can be installed in tight or unvented spaces (ideal for RVs, basements, or island sinks).
- Resistant to freezing, since there's no standing water to expand.
Maintenance Requirements
Waterless P-traps require
less frequent maintenance than traditional ones, but there are a few important steps to keep them working:
Maintenance Task | Description |
Periodic Inspection | Check the valve/membrane every 6–12 months for debris, wear, or sticking. |
Cleaning | Remove and rinse the valve to clear hair, soap scum, or other buildup if drainage slows. |
Replace When Needed | Silicone membranes or valve assemblies may degrade over time—typically 3–5 years. |
Seal Check | Make sure the trap closes properly to block odors. If you notice a sewer smell, it may be due to a failing seal or stuck valve. |
Use as Intended | Avoid harsh chemicals or drain snakes that might damage the membrane or mechanism. |
