Servicing The Wheel Axle Bearings
jagibson58
In the next three we will be servicing our wheel axle bearings.
2024 Alliance Paradigm 310RL
Where is the best place to jack up RV on the frame safely to lube the EZ LUBE bearings?
A picture would be helpful.
I never use the ez lube. I recommend inspecting and repacking the bearings every year.
If you do jack one wheel up at a time, place your jack as close to the wheel/tire as possible, and rotate the hub while you are applying grease slowly. Once you see new grease coming out the outer bearing stop.
Things that can go wrong. Apply grease to quickly and you can unseat the seal do to hydraulic pressure and the grease will end up all over your brakes.
Once again removing, cleaning, and repacking is the way I would recommend. Also if you do remove I always recommend doing one wheel at a time so your bearing and races stay matched up and also use some high temp rtv on the outside of the seal when installing it.
I'm aware that I'll get some blow-back on this but here goes...
If you have a bottle jack you absolutely can place it on the axle on or between the U-bolts. Don't place it more than a few inches inboard of the U-bolts or you do risk bending the axle. For safety place a jack stand just inboard of the bottle jack but don't lower the axle onto it.
I'm not a fan of lifting anything higher than needed. For servicing wheel bearings or changing a tire lifting by the axle is fine. For suspension work you do have to lift by the frame.
By lifting on the frame you'll be hanging both axles off the ground and risk flipping a hanger which is a pain to get back. And unless you like seeing your trailer leaning over precariously you'll probably need to lift both sides. Not to mention the extreme flex of lifting only one side.
As a last resort — as in side of the road flat tire — I admit to using the leveling jacks to change a tire. Ain't recommended but it's doable.
Note that the axle intentionally has a little bit of a bow for pre-load. Don't think that it's already bent.
Here is Dexter's warranty for people saying you'll void the warranty. I'm sure they may deny a claim if you bend the axle lifting it too far inboard but you will not bend the axle by lifting at the U-bolts. I'll not be convinced they'll deny a claim if they see scratch marks on the axle between the U-bolts.
jagibson58
Looked under the rv today, only problem I see is that on the driver side frame is that there is a propane line down the length of the trailer. Would be nice to a have a frame schematic.
This is what I was able to do. Using the back jack and side jack, I was able to lift each tire enough to turn each one. I positioned one lug at 12 o'clock. I then removed the tire. When putting on the spare (Because rim was damaged when brakes fell off)...that steel rim spare is a heavy BEAST...I was able to rock the spare back and forth, while slipping in wheel chocks on each side,,thereby raising the tire...slipped it right on.
If I was on the side of the road, I would use a bottle jack, if I could reach the additional height to the frame. The Dexter mobile tech, did exactly what George stated, when fixing my brakes.
My F350 dually manual says not to jack on the axel, but many tech's say it is no problem...I guess the debate rages on! I say, do what you can afford to repair...LOL!!
Everyone frets at using leveling system to lift rig to make repairs. However the 2 times I had the pros work on it they used the leveling jacks to raise trailer.
All leveling systems are not created equal. Some are robust enough to carry the weight some are not. Jack stands should also be used to hold the weight once lifted.
I would not say lifting with jacks is OK as a blanket statement, however with care and know how it can be done.
Same can be said for raising trailer via axles, with care, correct positioning of jack it can be done without harm.
