New Delta setup for seasonal camping question. Is there any issue or concern in blocking under the frame in front of and behind the axles for yearly or multiple season setup ? The only thing I see to watch for is the hydraulic line.
Hi folks, I see no one chimed in here.
My opinion would be as long as you are making direct contact with the actual frame I wouldn’t see a problem with it.
Don’t pinch anything between your frame and supports, and raise it enough to take the long term load off of the tires.
If you choose to remove the tires, I would suggest some support under the axles , so that aren’t hanging under their own weight long term.
I would suggest placing a piece of wood between the frame and whatever you choose to support it with.
Be careful , work safely and be sure things are 100 percent stable.
