I am trying to get my tailgater to my wally to work with the in house coax cable. Right now it is run from the tailgater to my wally through the window. I have ohmed from input at the nautilus panel to the connection at the amplifier. I then ohmed from the connection to (after removing the coax on the backside of the amp) the wiring that goes to the wally (7.7 ohms). I then hooked the cable from the tailgater directly to the cable coming from the backside of the amp, would not work. Hooked the tailgater back through the window and it worked. My cable from the tailgater is 50ft. Is the extra coax length causing my Wally to not be able to get a good signal? I have a 2023 295MK.
