94wamiadga94
Animation toilet will not stop filling with water
I believe those use an electric solenoid to fill the bowl with water.Darn autocorrect. Sanimarin toilet
Do I remove the toilet to get to the solenoid valve?I believe those use an electric solenoid to fill the bowl with water.
It could have debris in it that is causing it not to seal properly, or maybe someone wired it incorrectly.
Should be a simple fix .
We don’t have one of these, so I can’t say for sure. You should be able to follow the water line from the coach that feeds the toilet. The valve would have 2 wires attached to it, plus the inbound and outbound water lines. Are there any removable panels or openings on the rear of the base?Do I remove the toilet to get to the solenoid valve?
Thanks. The issue actually was too high water pressure.We don’t have one of these, so I can’t say for sure. You should be able to follow the water line from the coach that feeds the toilet. The valve would have 2 wires attached to it, plus the inbound and outbound water lines. Are there any removable panels or openings on the rear of the base?
Glad you got it figured out. I didn’t see a max psi spec listed in the install manual.Thanks. The issue actually was too high water pressure.
