RV LP Port
kmac7800
I tried to use my RV quick connect propane port on my last trip. I got a hose that had the male 1/4" quick connect on one end, assuming that is what went into the port. Alas, the port is MUCH bigger than 1/4". My question, is it 3/8" or 1/2". Here is a picture of me holding the 1/4" male quick connect up to the port. I have a 2020 (2021?) 310RL.
Thanks in advance!
//Karl
Yes I believe they are all quarter inch. It can be a little tricky You have to push that fitting in, the spring loaded portion push it in and then insert the quarter inch end of the hose.
Dealerships could install anything, so I am not surprised. Based on your picture, your quick connect is not 1/4". Since your grill line is set (pre-made), then go to lowes, ace, or home depot and work backwards. Turn off the gas (remove the fitting) and take your pre-made grill line with you. They will have the correct 1/4" quick connect (with a shut off valve) or get you to a solution to the transition. This has been covered under another thread...but...if in a pinch...go to a hydraulic shop and they may have the fittings to make the connection you need.
Granted anything could happen. But those fittings are generally factory installed.
WE3ZS
Did you actually try to connect the two fittings? If so what was the result? It looks pretty typical to me, the outer opening is much larger than the internal seal ring.
Thanks in advance!
//Karl
Did you push the collar back? very likely a stupid question so apologies in advance if so.
Do your bbqs work off that port? Mine was regulated at camper and then on bbq valve and I could barely get any gas’s out?
Yes all of my grills, Blackstone, propane fire Will work from the Are the external Lp quick connect. Often you have to remove the regulator from the appliance if connecting the RV Quick connect net. I have an assortment of LP hoses on my various appliances to connect to the RV Quick Connect or a traditional LP tank
kmac7800
Actually I do not think I did because I was taken aback by the large discrepancy. I will do so when I get home and see what I get (while pushing the outside collar back ;-).
Thanks guys!
//KMac
WE3ZS
I think that you find that you are good to go.
I replicated your picture with my factory LP quick connect and my Blackstone hose, looks pretty much the same as what you had shown.
And here they are fully seated.
Looking at the pictures closer, it does look right. In addition...the quick connect (Female side)...should have a stamping on it, to indicate it's size. If it is just simply, not pushing back the female quick connect collar and then inserting the male end.....then I refer back to my previous post.
kmac7800
After this reply from Alliance:
"Thanks for reaching out, our records indicate that this would be ¼” , I believe it is a type 250 according to what I saw online. If it isn’t ¼” and you have verified the only other size it could be is 3/8”, but everything we have shows ¼” diameter."
I have indeed verified that my LP port is actually 3/8" and I will finally have a way to use my BBQ (it's regulator died and it was using the 1 lb LP cans) and my new Slinky Stove dual fuel. However, renting a crane to get the Slinky Stove from my house to the RV, and then again when I go to set it up may slow me down some ;-)
Good luck and have fun!
//KMac
