Renogy 100ahr.. Max charge rate spec is 50amps .. that apply if its a bank ?
johnda98
ie is it ok to push 70amps into a bank of 3 x 100 amphr batts ?
or does 50amps limit apply to the one batt or a bank of batts ? (up to 5)
Forum Moderator
That depends on each battery model and which BMS they use. My Battle Born are rated for 100 amp charge and will increase with each battery. I have 3 and limit it to 150 amps...I figure that is plenty for my 810 amp hour setup.
darrell
If your charger outputs 70 amps, you will divide 70 by the number of batteries you have to get the amount to each cell in parallel. You will be fine.
johnda98
renogy has a Discord server.. fairly responsive.. yep.. the full spec for a bank..
