Hokiecrew81
On a recent cross country trip, the plastic membrane that protects the insulation under the two main cabinet slideouts which extend over the tires ripped allowing moisture to penetrate to the insulation. Before I realized what was happening the insulation became completely saturated and the added weight caused the plastic liner to rip further, further soaking the insulation with water and road crud. This happened on both sides of the RV.
Has anyone dealt with a problem like this before? If so, what is the best way to perform the repair. Pictures attached are of the plastic frames that helped hold the insulation/plastic in place along with the crud filled insulation and plastic liner so you can get an idea of the mess created. Question is how to replace it so it stays intact?
