dhcolesj
I've looked all over and cannot find a pull handle with a male thread on the end. The back (or rear) gray tank valve pull handle came off somewhere in Arizona, and I need to find a replacement. Anyone here know what I should be searching for? The rod sticking out has a female threaded hole, so either there was some kind of adapter between the handle and this rod, OR, there was a special handle. This is on a 2023 40v13 and it's the gray tank handle under the slide out.
Having no access to any kind of microfiche layout I have no way to find an OEM part replacement.
Anyone else out there had to replace this?
