Don't think that is correct. With my F350, After towing, I fill up and it will show the distance that the MPG indicates. I laugh cause as I drive, My MPG goes up and so does the distance to E. Start out normally about 700+ and drive and I end up with over 800+ to E. I'm getting 19 MPG back and forth to work. Don't think it takes the average of towing and not towing. It just uses the Avg MPG. Can't see why they would change it between models. Do believe it has something to to do with the shape of the gas tank. They could only put the probe in at one location but it can not read all the fuel until it gets to a certain level that it can measure. They use floats not vertical probes in the tanks I do belive.
Happy Glamping!
Have driven Dodge/ Ram gasser Hemi HD trucks my entire adult life. Towed extensively as a gen. Contractor,,,& avid trailer camper & traveler,,,,Have had auxiliary tanks but never a 50 gallon stock fuel tank,,, Am 90% certain they average based as explained by Flyer32RLS above,,,have had various tuners for different performance needs,,,economy,,,4WD,,,towing,,,performance & those selections would adjust shift points,,,tire size,,,& monitor major drive, transmission, fluid,,,fluid temps,,,always found the types of behaviors noted above,,,but also always found you could rely on trusting DTE would be close to reality for travel purpose of remsing fuel. Our current rig is a 2015 HD 6.4 hemi,,,and has dash setting on engine,,,that reflects actual measurements on major components. It is to the best of my expience set for specific truck equips at time of mfgr,,,never have had to have recalibrated due to tank size but this info is only based on personal experienc,,,people trainiedin theses matters are much smarter & knowledgeable than I. Just my $0.02 for your info,,,
