Pump Not Pulling From Tank
2 Allies
This usually points to an air leak or restriction on the suction side of the water pump. Common causes include a loose inlet fitting, cracked hose, clogged strainer, or a failing pump check valve. Also confirm the fresh water tank has adequate water and the tank vent isn’t blocked. Tightening connections and cleaning or replacing the pump strainer often resolves this. Issues like this are fairly common in RV systems, and resources and guidance from RV-focused brands like Popular RV can be helpful when troubleshooting.
Very concise and accurate. Are you an AI bot?
Top942002
Update on this issue. Draw tube to the fresh water tank was NOT connected to the tank. Add this to the black tank flush line being capped off and I wonder how this unit passed quality checks. Perhaps anything that deals with water is not checked on the way off the line. Pass the problem to the customer and dealership.
Top942002
Correction to fresh tank connection. It was a broken elbow fitting and the lines were reversed. Fill line was plumbed at the bottom and draw line was at the top. Unfortunately, the connection required pulling the belly to get to.
LOL — Likely since @Popular RV account was created 1/18 and last seen 1/18.
Guess it is time for me to do a little house cleaning... :cool:
