Pinched leveling hose
Tgrfan2
A heads up on the hydraulic hose feeding the right rear cylinder on a 2022 Paradigm 385FL.
I saw fluid dripping near the cylinder today and took the cover down behind the right rear wheel. The hose had pinched at the tank and frame before passing through the frame to the cylinder. I guess that pinch point was used instead of a clamp to hold the hose in place. The rest of the way over to the left side it just flops around like all the wiring.
I'll fix that while installing new 8K axles that should have been standard on these fivers from the beginning.
I hope this post will save someone some downtime and a spoiled camping trip.
