Do you have any outlets in the kitchen island? I would have bet for sure that is where your 2nd GFCI outlet would be.I thought it might be kitchen, but I don't have any GFCI in the kitchen or island
Only one circuit breaker for one GFI circuit?no I only have 1 thanks
yes thanksExcuse the question...but are you on shore power? Do any outlets work?
didn't think about the breaker at the campground. I don't have a meter with me to check Just checked all 3 AC and the rear nit also does not come on.As others have stated, I would have guessed that you have two GFI circuits and one of them need to be reset at the outlet. Our 310 RL has one in the bathroom and one on the end of the kitchen island. Not sure about your 390MP.
The water heater can be equipped with a switch that is located behind the cover that might need to be turned on.
Also there are thermal resets behind that cover as well that might have tripped.
I guess the other possibility would be that, given you have outlets and a water heater not working , there could be a possibility that you might be missing one leg of your 50 amp.
Do you have a transfer switch ?
Just sharing random thoughts out there.
That sounds like you might be missing one leg of your 50 amp.didn't think about the breaker at the campground. I don't have a meter with me to check Just checked all 3 AC and the rear nit also does not come on.
Glad you found it. I hope it's a campground problem.Just checked my surge protector and it shows missing 1 leg, Thanks for the help
Happy to help, glad you have identified the issue, now comes the fix !!!!!Just checked my surge protector and it shows missing 1 leg, Thanks for the help
