Opinions on slide out toppers.
DanNJanice
Just wondering what everyone's thoughts are on slide out toppers?
I am thinking about getting some, after the leaking issues on my new Avenue. I feel I have resolved any leaks, but you never know.
Here is what I have found so far by searching the internet:
Pros:
Shed rain, reduces chance of leaks.
Prevents debris from getting on top of the slide.
Keeps room cooler by providing an air gap.
Cons:
Noisy - If windy, the slide material flaps around. I have seen reviews of many attempts to resolve this (beach balls, etc.)
Somewhat easy to damage - Can be damaged if wind is too high. Most recommend pulling the slides in if the wind is over about 30MPH. This could be a real inconvenience, especially if I am not at the trailer when this happens.
Now for some questions:
Do you like your toppers and would you put them on again?
What brand are you using?
Alliance says they are prepped for Carefree toppers, are these decent quality/value?
Did you install them yourself and was it fairly easy (assuming good DIY skills) ?
TIA,
We are from Oregon...rains a LOT here. We have had slide toppers on our last 4 RV's and would NEVER own an RV without them. I have never experienced excessive noise from them. Yes....they will sag some after heavy rain, but that can be resolved by bringing the slide in or pushing up on them. 100% worth it for us.
DanNJanice
Thanks for the response, I am pretty sure I am going to put them on.
Do you have any brand that like more than the others?
We are also from Oregon and we have a 340 RL with toppers. I would not have a unit without them. They keep all the leaves and Pineneedles off the top of your slides and when you pull in the side it keep any debris from following in the top slide mostly.
Whitewolf
I'm also a fan of slide toppers. I had them installed on our last 5r and when I order the 340, I had the factory install these. The only complaint I have is I don't think the factory mounted the topper high enough to the sidewall. They sit pretty flat.
DanNJanice
Thanks for the feedback. I will put them as high on the sidewall as possible to get some slope.
Hotrodjohn
Mine pulled the track off the building as well as slid out of the track and one was ruined at a campground by wind and was left in the campground garbage. They are nice. They suck. Had an Arcadia without and never had a problem.
Gord&Cindy
Anybody have any experience with these "True Toppers"?
Looks interesting, but we have the fabric style on ours now so I probably wouldn't change them to these now, but maybe on the next RV???
I have a friend who had this done on his motorhome. Of course, they're not really slide toppers but they do perform the feature of clearing the slide roof of water/debris as the slide comes in. The downside, in addition to the cost is that you lose slide roof shading that you'd have with a traditional slide topper.
MattDay870
This origin post was June of '23 so you've prolly already made up your mind LOL. But for anyone else reading this now, and are on the fence, here's my two cents. I've had slide toppers on two out of seven campers over the years, and I can do without them...My last two TT's I haven't had them. A Toy Hauler, and now my Delta 262RB. Less worry in winds, way less noise (my DW disliked them as she's a light sleeper!), less maintenence. Just less to fuss with. Oh, and the longer the slide, the noisier. If they're wet from rain? what a nightmare trying to get leaves or pine needles of it if you're trying to pack up and leave camp! Stuck like glue. Much easier to sweep off a hard surface than a soft surface that also gives. SO..I just stand on a step ladder and use a battery powered leaf blower to blow off debris before retracting, quick and easy. and I know nothing is getting rolled up it the topper material. As far as the thermal aspect, I've never noticed a difference. Hope that helps!
