Well, I actually found a service manual for the 12 volt refrigerator’s that we have. Unfortunately, it doesn’t mention any thing about handle repairs.We have a 385FL fifth wheel and we have an issue with our refrigerator right hand side handle. It seems to be disconnected from the cable in the door. How can we fix this. Thank you for any help.
rvbusiness.com
Bryan, two questions:Attached is the Norcold service bulletin describing how to install the replacement door latch cable. This document was provided by Thetford which owns Norcold and now with the Norcold bankruptcy they have stepped up to the plate to make Customer Service a positive experience.
I completed my cable replacement today. Removing the door is necessary as the bottom cable latch attachment to the locking pin is a little tricky and gravity is not your friend in this case.
I ordered the part on-line from someone other than Thetford or Norcold. It was PDX RV LLC through eBay.Bryan, two questions:
1. Did you have to contact Thetford directly or was the cable found online? I can't find it on their website.
2. In case it cannot be found for sale did it look like something you could fabricate from or repair with aircraft cable?
AtDhVaAnNkCsE
To me, it appears unlikely that the part can be fabricated from other components unless you’re exceptionally gifted.
