SandDragger
Long story as short as possible. Let me start off by saying this is not a bash thread, just a huge level of frustration setting in. This is our fourth 5th wheel purchase and what we considered to be our last. Went back and forth between Alliance and Brinkley. We settled on Alliance because of all the good things I have seen/read regarding them over the past year(s). Owning 3 other 5th wheels, I am 100% expecting to see issues with a new unit that will be repaired. However, we have what I consider major issues our first 3 trips. First trip (among other issues) involved a leak at the shower head that I didn't catch until 2 days into our 7-day trip. Water had been running down the wall, on top of the water heater, on top of the furnace, then eventually leaking on the subfloor and ground. Finally figured out where it was coming from and shut the valves off to the shower. So, we were stuck with no shower for the remainder of that trip. Took it back to the dealer for that and other issues. PEX line was cracked. 2nd trip started noticing the same issue, so we were stuck again with no shower. Back to the dealer to where they found a cracked PEX fitting by the showerhead (which probably should have been identified the first time). At this point, I had already been voicing concerns about water damage from the first trip. I may just be over worrying, but nobody else seems concerned that water was running down/sitting on the wall studs/subfloor/etc. for days.
Third trip, we arrived at night, and I didn't hook up sewer connections until the next day. Unfortunately for me, the bathroom had already been used. All valves showed closed, so I slowly opened the cap (I stress slow from previous issues...). As wastewater starts gushing out, I put the cap back on. Realized the fuse was blown in the automatic gate valve switch. Get a new fuse and I see power, so I shut the valve only to hear an odd noise I'd not heard before. Attempt again only to realize the valve is still not and will not close. Switch shows the valve is open regardless of where the rocker is. Going back to our first trip, when I dumped the black tank, I had a restriction that I had to stop draining to pull the sewer host and clear out the issue in waste. What I found was (2) cutouts from the hole saw they used to cut the openings for the PVC pipe. So now I'm left wondering if something else was in the tank which caused my gate valve to break. So, for that trip, we were left without a functioning toilet.
I have been in constant contact with Alliance for these (and all the other issues). Yes, the issues are being fixed when found. However, it's more than frustrating to have these major issues that prevent us from using the shower/toilet on our trip. It's also frustrating that the closest dealership (which is where we purchased) is about 1 hour and 20 minutes away. So, each time we take this back to the dealer, we are 3.5 hours or more out of a day. You are looking at 7 hours of time/gas/etc. for us to take to the dealer each time we have an issue. The dealer was actually good enough to come pick it up the 2nd time (I assume because we had the same issue that they were supposed to have fixed). But I am still looking at 14 hours of time/gas/etc. so far just to have used this unit 3X.
Am I just being too picky? We have had the "lowest end" 5th wheel and upgraded each time. All have had issues, but none had issues that prevented us from enjoying our trip until we could get back, until now.
If I'm just being too picky, feel free to tell me so.
