Mounting TV on bedroom wall 32RLS
sleepyT
I'm trying to mount the flat screen TV on the wall and using a stud finder to find solid area which was NOT marked form the factory...The stud finder is giving me false readings...Just drilled a hole that seemed to get a good reading and no mounting board behind the inside wall...If anyone here has already mounted their bedroom TV in a 32RLS please let me know the location of your mount...I did get a good reading on the wall in between where the electrical and cable boxes on the ceiling are but think that might just be a stud because the reading is just an inch in width...Any help is appreciated..
JWalker
Try using a strong magnet. Our Avenue had a metal plate in the wall. Not wood.
sleepyT
Jamie
Thanks for the reply...By the location in your picture the mount is not centered in the window...I will try the magnet...I also assume you used self tapping sheet metal screws...
JWalker
Yes. We have a Avenue 30RLS. so the tv placement is on a different area. 1 1/4”Self tapping screws.
JWalker
Yep. Worked well for finding the edges.
sleepyT
Yep...yours is the same mount I have as well...Thanks again from a fellow Pennsylvanian... (South East)
CharlieO
We have an Avenue 30RLS that should be delivered about the 1st week of April. Trying to pre-purchase items so I can get a jump start outfitting it when finally arrives. What do you think is the max size TV that can be mounted on the bedroom wall?
JWalker
We installed a 24” TV
