Your very welcome, we have a 2024 310 RL. I just walked out and measure the inside dimensions of the pass thru(door side). Ours is 46 inches wide and 30 inches tall inside edge to inside edge. I have never seen a compartment weight limit published. Hope this helps!thanks Bryan,
the cricket sx3 weighs around 400 lbs and is collapsible to these dimensions :
The SX3 collapses to
58" x 32" x 28"
I'll have to research the 310RL Basement access door and compartment dimensions and weight limit
Bryan,Your very welcome, we have a 2024 310 RL. I just walked out and measure the inside dimensions of the pass thru(door side). Ours is 46 inches wide and 30 inches tall inside edge to inside edge. I have never seen a compartment weight limit published. Hope this helps!
We love our 310 RL!
Edited: How in the world would you manage loading and unloading 400 lbs?
There is a raised lip that forms a ring around the compartment.Bryan,
thanks for measuring the basement cargo access door dimensions...theoretically the "collapsed" cricket should fit at 32" wide and 28" height (58" long).
cricket also sells aluminum ramps that can be used to power the cart up and into the cargo space using a separate remote.
hopefully the ramps on the edge of the cargo access would rest on solid surface and weight of ramps and cart would not damage anything.
is the bottom lip of the cargo access a raised lip? is it fragile or solid?
I'd rather use the rear hitch but like you said 300lb weight limit would be exceeded.
