Locating where to cut "Coroplast" underbelly
I'm not having problems yet but when I do how do I locate the dump valves on a '24 Paradigm 310RL?
Either measurements, a schematic or a top down photo of the 310RL in production before flooring would be nice.
Thank you
Can you tell me which is black tank, kitchen tank, and bathroom tank. I’d like to mark up diagram with this info for future reference. Thanks.
The best way is to look at where the drain pipes go. Units may not be the same two days in a row. The black pipe from your toilet will be much larger than the black pipe from the other drains. (and of course where the large black pipe goes will be your black tank)
Upvote 0
Dduncan340
Did you add the mopeka sensors to your CerboGX via GUIMODS? I've heard that is possible. Would like to see it in person.
I added The Mopeka to my Fresh Water Tank a few days ago. Really easy to do! I used an 8" Access Cover for battery replacement. This is via Cerbo GX. The access hole is in front of the Dump valve about 3". There is a crossmember in the photo, keep that in mind when you cut the hole. I put this sensor in because we camp year-round at sites without hook-ups, really like to know how much water is remaining!1740595358621.png 1740595436223.png20250223_171313.jpg
Upvote 0
I added The Mopeka to my Fresh Water Tank a few days ago. Really easy to do! I used an 8" Access Cover for battery replacement. This is via Cerbo GX. The access hole is in front of the Dump valve about 3". There is a crossmember in the photo, keep that in mind when you cut the hole. I put this sensor in because we camp year-round at sites without hook-ups, really like to know how much water is remaining!View attachment 3142 View attachment 3143
I now have the same, except for the Fresh water sensor.
Upvote 0
