Alliance design/ engineers..
for OHV toy haulers.. access to OHV areas and esp in Moab.. those fireroads when deep ruts dryout. can be hard sand/mud and can damage the low clearance jacks if not really careful
Might be great on Toyhaulers to bolt the jacks onto a rotating 90deg backplate.. similar to a jockey wheel on a small trailer for the nose weight..
sort of a tilt and lock with a spring bolt.. so they can cant up 90deg fore and aft .. increasing clearance near the axles
next lowest point to hit might be the sewer outlet and fresh water pull... maybe a pull on the side for fresh ?
sewer.. maybe have a option of a slip on coupler on each side just before the sewer exit.. so a owner can remove the lowest part of the plumbing
