Kitchen slide not plumb
Spanter
We bought a new 2022 Avenue 30rls a few months ago and notice the kitchen slide is out of plumb on outside about 3 inches.
On the inside it appears to be fully extended.
Is this something that can be adjusted or any suggestions on how to fix it?
Mike in North Wales
Are you saying the outside wall of the slide is not plumb, or parallel with the main wall? If so, that is the shape of the slide box. It has to do with sealing when the slide is closed, I believe.
Have you checked the seal inside when the slide is extended? It it against the inside wall all the way around?
Spanter
Hi Mike, yes it is not parallel to the side wall example bottom of side is 25” from side wall top is around 22”
the inside seal seems pretty tight all the way around.
it just looks odd all and Noticeably different than the other sides.
