Meanjean73
I see some people have them and other don't. Are they needed or just a nice to have item? Im guessing it depends on what 5th wheel they are being used on if they help much?
Which one are you using?View attachment 4530
This is my setup. Light weight and works well in minimizing the movement in the front of the unit.
What's different about the rear mount versus mounting the stabilizer in the front?I use these on front and rear I beam, made by morryde. For me the tripod just did not do much. These are amazing in my opinion.
No difference in application. However the front is more subject to wiggle. Because the landing legs are not as supportive,robust,solid as the rear wheels. Granted you can get wiggle motion from the rear wheels as well.What's different about the rear mount versus mounting the stabilizer in the front?
I agree with Lantley, we use one for longer stays. Jiust for an overnight, its not worth the effort. Seems to reduce the wiggling when walking but for an overnight, usually don't do much but eat and watch a little TV and sleep.I have one and don’t use it much. It still helps with wiggle but just don’t see the need for it for short stays.
Found these on Amazon, same type as the Moryde
Beam mount stabilizer
