trickyricky
Has anyone changed a hydraulic jack without hooking up the RV to your Truck?
I have a leaky one on my 2026 Paradigm 382rk
I would call it number 2 on the left side with 3 on each side.
Do both rears on one side move simultaneously when I go into manual mode?
I have blocks under the frame now beside each jack but, I am still a little nervous to start on this project.
When I remove hydraulic hoses the jack needs to be in a retracted position correct? I should not loose much fluid that way.
Just want some reassurance I'm doing it correctly.
