Unhappy Buyer
Here is the first go around!
Dead battery on pickup that would not hold a charge- This is still a continuous issue, and nothing is being done about it.
Compartment door flew open due to lack of locking mechanism, causing damage
Molding detached in the bathroom, causing further cosmetic damage.
Missing recliner power plug, rendering it unusable
Molding issues in the dining slide and toy hauler area
Entry doors do not close from the inside, despite being told this was resolved before delivery
Recliner material already bubbling/ripping
Happi-Jac system intermittent functionality (possible electrical fault)- Because it worked when Campers Inn tried it Alliance stated that there is no issue!
Incorrect plumbing (hot water in kitchen sink is plumbed to washer connection)
No sewer pipe identification stickers- Still not on the Camper from the factory
Storage bin light strip that does not turn off
Molding fell off above couch- Large wooden piece
Above the entry door to the toy hauler molding fell off
Main entry door the lock doesn’t work
Door jam going out to the toy hauler is separating
The Living room AC isn’t blowing out cold air
Dining room window is leaking
Second go around
Second go around
- Battery Issues
Since day one, the battery has consistently been dead even with everything turned off. When the customer came to pick up the unit on Sept. 27, the battery was dead again and the slides would not work, but the tech was able to start the generator. The refrigerator also seems to turn on by itself. Even after verifying shutoffs with John at Alliance, the battery continues to drain. - Bathroom Trim Repair
The trim was repaired with white putty that does not match the wallpaper and the holes remain visible. The putty was peeling off by hand. - Bathroom Trim Gap
The reinstalled trim has a large, visible gap from the wall. - Recliner Repair
Bubbling was addressed, but the surface now feels uneven and rough. - Ripped Flooring
The flooring on the dining room slide is ripped. - Dining Room Window Caulking
Exterior caulking was poorly applied and is visible on the paint. - Sewer Tank Labels
Labels sent by Alliance were not applied. Campers Inn was unsure which label matched each tank. - Dining Room Chair
Paint is peeling. - Happi Jac works piratically
- Doors would not close or lock-that was fixed
