Well, talk about a big disappointment. I ordered the RAM Trailer TPMS monitor system with my 2024 Ram. The sensors come package loose when the truck is shipped from the factory. So, I knew I had to install them into the trailer wheels. Well today was the day to test fit one! What a disaster to say the least. While the sensors come with 1/2 and 5/8 rim hole hardware, the sensor valve stem threads are not nearly long enough to properly install the nut on the outside to hold it in place. The instructions call out about a max of 6mm rim thickness and the wheels on my 310 RL are about 9mm. So the 5/8 hardware was a step in the right direction for the 310RL wheels but, the thread length on the stem was the deal breaker. Of course, the only way I could figure all of this out, was to remove the wheel from the trailer, break the tire bead, remove the old stem and test fit the factory supplied sensor. Needless to say this took some effort and produced no reward!
So, I had to reinstall the original stem and reseat the bead etc.
Hopefully, this post might prevent others from experiencing the disappointment and wasting a lot of money on the factory option that won't work on our Alliance wheels.
My question is this, is anyone aware of a compatible internally mounted TPMS that will work with the RAM System and @9 MM thick wheels and5/8 hole?
