Inverter output wiring...
DanNJanice
I have a factory installed PD1620 inverter in my 2022 32RLS. I connects to several outlets, however it does NOT power the outlet for the bedroom TV.
My question is, where are the connections for the inverted outlets made?
They are not on any of the breakers.
There is just a piece of yellow romex that goes from the output of the inverter through the back wall of the front passthrough.
I have a suspicion that everything is tied together in a junction box in the underbelly:(
Hi Dan, this is only a guess, but given that your dealing with 120 v ac, I would think that they would be landed on a breaker panel, power management system or transfer switch somewhere.
Seems like it'd be something like this diagram. May not match your power control center but I would bet the inverter output goes to it.
Just basing this on past experience in another camper.
Socal-Paul
Since only several plugs are on the inverter my guess is they are run in series and there is no junction box. You might be able to run a new line from the closest inverter plug or from the inverter itself. I've had good luck fishing wires through the bathroom walls into the basement.
I extended my inverter circuit to supply power to the microwave by connecting a new outlet to a outlet on the existing inverter circuit.
