Intermittent power issues
For three years, we’ve been chasing intermittent power issues in our 30RLS. We dealt with flickering lights, a malfunctioning Lippert leveling system, fridge that would stop working sporadically then start working again and batteries that refused to charge properly. Every time I had the batteries tested, they came back as "low charge but OK." Even after a full recharge, I was only getting between 10.2 and 11.3 V instead of the usual 13+ V.
Working my way through anything that could be the issue, I finally pulled the cover off the bus bar and found the culprit: seven cables had zero nuts securing them to the posts, and they had already vibrated halfway off! When I pushed the cable ends against the bus bar, battery voltage jumped.
I've never found any loose nuts around the batteries so I have to believe these were never installed in the first place. Thankfully, it seems like it may be an inexpensive fix. True test is our next outing in a couple weeks.
Omg, 3 years to find this,! Congratulations, you should have a high confidence level that your issues will be resolved after securing those connections.
This is why I have always spent a few minutes each season going over any electrical connection that I can find to ensure that it is tight.
You should be confident in your findings, congraulations!
A second look at your picture, I count 8 missing nuts, one is missing on the Buss bar side as well!
The Witness marks from the star washer would at least support that it was there at some point!
It never dawned on me to even look under that cover. 🤷‍♂️
