Hydrolic Jack fluid resivor level?
I attached pictures of my hydrolic leveling Jack res. With front Jacks down only, my question is how much fluid should be in tank? There is No Fill line on the jug? Also what is A brand of fluid you recommend?.
MR, take a read thru this, page 10 for your direct questions.
Make sure all gear and slides are retracted before checking your fluid level.
Do not add more, unless ALL jacks are up and all hydraulic slides are in (Kitchen/Dining). Then you can see the true amount of fluid you have in reservoir.
I will admit that I did not follow LCI's instructions about how to add the fluid. I just sucked out a quart and added a quart of fork oil. I figured the instructions were for an immediate fix for popping and the fork oil would likely get mixed in just fine after a few operations.
BTW MR - sorry to hijack your post about checking fluid level with anti-stiction replies.
