Excellent, thanks Jim! Brenda (my wife
) and I purchased a 2022 Alliance Ave 30RLS new, it came with this package:
The salesman told us the bedroom would have dedicated power from the inverter, and that would be from the bedside outlets. However, the only place we can get power from (when on battery) is the TV plug in the bedroom.
We do get power from the CGI outlet in the kitchen, the fridge runs, and I believe the TV plugin (need to double check) - we've tested those for sure.
Here's a pic of what the solar was setup as from factory (not connected) - so solar didn't work until we figured that out last year ;(.
From what I've read, others have had those actually arching, so glad we found that... Now solar will charge the battery.
Here is an older picture from the panel:
Bottom right side of the panel - these seem to be what you're referring to above as dedicated for the inverter?
This is above the lower right picture - took these when I was working out the solar issue I mentioned above - will get a complete picture later today.
Last - here's the inverter next to our battery (we upgraded from the traditional batteries - we had two running, as our 12v fridge would only run about 12 hours off dual marine battery). We've run this w/the 12-volt fridge for 2-days last season and it kept up with the fridge.
The inverter works, we can get power to the outlets I told you about, just not the two plugs bedside when on inverter.
Going to check the unit this afternoon and will see what I see on the panel and get a picture of the entire panel.
So, is this perspective accurate? The wiring from every plug-in, appliance, etc. runs to this distribution panel, as does shore power and battery power. The solar package charges the battery. So, if we need to switch the inverter run outlets, is that done at this spot? No need to run more electrical wiring, etc.? If so, I was over complicating this in my head.
Thanks!
Dave
