You will need to check your converter make / model. Some have a switch that needs set to the battery type and some are auto detect. We have a 310 RL, so it is equipped with a switch that needs set accordingly.I just picked up a Delta 252RL and I want to use a lithium battery. Other than the solar charge controller, do I need to change a setting on anything else? My concern is charging when connected to a pedestal or generator?
Thank you. I thought so but, I have no ideal where the converter is. I found the A/C breakers and the DC fuses. I know where the solar charger is. I have no idea where to find the converter.You will need to check your converter make / model. Some have a switch that needs set to the battery type and some are auto detect. We have a 310 RL, so it is equipped with a switch that needs set accordingly.
