Hello everyone
Terri&KevinGates
I’m assuming this is what you are asking about. The trim board is too long so it catches on the flooring when it goes out and folds it. We used an oscillating saw to cut about 1/4 inch off the bottom. You should be able to slide the vinyl in and out under it. i think some heat from a hair dryer and some weight on top should help. Ours is still wrinkled some but not nearly as bad as it was.
