Grease Seal Failure
Dan54
Had our bearings repacked for the 1st time in our 2024 Paradigm 340RL. Was notified by the tech that all 4 grease seals had failed necessitating replacement of brake assemblies & hubs/drums w/bearings. My question is I thought this was a frequent issue due to production line errors? I searched & couldn’t find the thread. Not sure there is anything Alliance will do anyway since it is over 2 years old. Thoughts? Thanks
You might try Alliance but given the age I would be surprised if they would participate in a maintenance task.
I would recommend contacting Dexter ( the axle manufacturer) and plead your case.
I am surprised that weak braking wasn’t detected ( or maybe it was and not mentioned)if the contamination was present on all 4 wheels to the point that all of the assemblies needed replaced.
Several member have had success getting Dexter to participate in their repairs.
Good Luck!
UFF
In 2024 did they repack by removing, cleaning, and repacking or did they just use the grease fitting? Why would your drums and bearings be bad because of a seal failure. Most of the time all that needs replaced is the brake assemblies. It is a little odd all 4 are bad. Did they show you all the bad parts? Also the seals should have had a high temp sealant put on them to prevent them from unseating. Seems a little fishy to me.
Alliance or Dexter would not do anything if you have had them repacked once already and they were fine then. Who ever did the work I would be questioning. Also this should be a yearly task if you are using your trailer.
UFF
I guess I read the above wrong. My bad. This is the first repack. Still seems odd all 4 are bad. Good luck getting help. It is a yearly task. I would still want to see the bad parts. Drum don’t go bad because of grease, they just get cleaned up, new bearings, races, and seals can be put in them. They would have had to pull a 4 hubs to say all 4 are bad. Pics would be nice.
