I have the 295MK - How is the best way to remove the generator shield? Can it be remove thru the front storage opening without cutting it up? Any ideas or suggestions?
Thanks in advance r
Thanks in advance r
Delayed response, as I just did this. 9 screws covered in silicone. 6 are easy to get to. The 3 between the shield and door side propane compartment require me to climb on to of the generator shroud and remove the screws. Alternatively, I suppose you could use vise-grips and screw them out from the bottom. It fit out the storage door.
