Furniture fabric peeling
simsfmly
Furniture fabric is beginning to peel on the theater seating and back couch on our 2022 340RL. Aside from just replacing them or throwing a blanket over them (which is what we do) is there any way to repair these?
I have no first hand knowledge, but other forums have posts sharing that the manufacturer will provide replacement upholstery. An aside, I’m going to put some form of UV block on the windows and use 303 at the end of every trip. Worth a shot I guess.
Sims
Pull it out and replace with your own furnishings. Replacement furniture in our case was lighter, more comfortable and less expensive than rv furniture replacement.
Shreck
Sims
I have been thinking about replacing some of ours with regular furniture. Should I be concerned with anchoring it down or does it ride okay just sitting in there?
M
My furniture rides fine.
When the two living room slides come in they hold the couch from moving forward and I have very little room for couch to move side to side.
My Lazy Boy doesn’t move as it is between slide wall and kitchen island When traveling. i also have a rug for living room floor I roll up and slide behind chair so chair stays in place.
The end table next to lazy boy I screwed down with a couple L brackets, just small ones work fine. The lamp on the table I just screwed into the table with Small pilot hole and small screw So you cant see it.
The hard part was finding a good couch to fit the space? I think we found it on Wayfair.com
Real furniture is more comfortable and in many cases lighter than rv furniture.
We have no original furniture in the entire coach. We replaced the dinning chairs as well.
