Bubblehead
What/how do you store things in there without bumping into control panels etc...Thinking some storage containers with tension rod(s) to prevent movement?
I’ve kept my black stone in there on the opposite side of the hydraulics .What/how do you store things in there without bumping into control panels etc...Thinking some storage containers with tension rod(s) to prevent movement?
I store my batteries in a pelican case. Its easily accessible, bolted down, and tough as nails. I made an aluminum frame to mount inside that can securely hold 4 Renogy 100ah Self-Heating batteries Might be over kill and pricey, but tough as nails. Just have not had a chance to add 40A an breaker after 3000W inverter and inline fuse to off the possitive side 4/0 cable feeding my 12v load side. It will go inside the Pelican case too.I currently use that compartment as my tool shop but its getting pretty annoying to duck down and stick my head up in the hole to get stuff frequently. I keep main power cable and several extension cords down in the battery compartment but I may relocate tools into a drawer system down there. The hyd. assembly is behind two removable panels in our '24 44v14 so I'm not worried about that and nothing has come close to hitting the Renogy controller.
Could just put a cover over it of some sort for piece of mind.
Looks nice Oregon! How many amp hours do you have sitting there?
810.....3 Battleborn 270amp hour batteriesLooks nice Oregon! How many amp hours do you have sitting there?
Have you put a temp sensor inside that Pelican box on a hot day with inverter running?I store my batteries in a pelican case. Its easily accessible, bolted down, and tough as nails. I made an aluminum frame to mount inside that can securely hold 4 Renogy 100ah Self-Heating batteries Might be over kill and pricey, but tough as nails. Just have not had a chance to add 40A an breaker after 3000W inverter and inline fuse to off the possitive side 4/0 cable feeding my 12v load side. It will go inside the Pelican case too.
Roger
