reactancexl
I have a 2024 paradigm 380 mp with the Norcold Frig. will I be able to keep this on while traveling? thx
We have no issues with refrigerator operation while traveling. We have towed as much as 11 hours without issue. Solar and the truck charge line keep the battery topped off.I have a 2024 paradigm 380 mp with the Norcold Frig. will I be able to keep this on while traveling? thx
What you may be remembering about level refrigerators is in regard to absorption type (propane) units.thanks for all the comments. My main concern was the level of refrigerator as it will be at a little angle when slide is in and normally they need to be level. As far as the batteries, I am not concerned as I have 200 AH lithium with solar panel and also a 48v system at 300AH which can charge the 12v system if need to be and also a onboard generator. I will check out the thermometer. thx
The 12v residential compressor types are not as sensitive to being level.
In re thermometers I like the Govee units. https://a.co/d/1PhyK7p for Bluetooth only or if you want them on wifi too... https://a.co/d/1eazFu2
Note that in the attached photo I have #1 & #2 both in the freezer compartment to check accuracy. My fridge is NOT -7º LOL
