Fan whine
TJJ
Is anyone experiencing an annoying fan noise in their dometic fridges?I was reading in another rv forum where people are replacing (upgrading) to computer fans and the noise goes away.
dwcfish
I had a similar issue with mine. When the fan was running I removed the upper vent and discovered that there was a metal baffle against the exterior wall that was vibrating and making the noise when the fan was on. Low tech solution.... Took a pool noodle, cut a few donuts and placed them between the baffle and the wall.... No more noise.
Whitewolf
I should probably check out the noise and see where it's coming from. Maybe this fall. Right now the A/C's are covering up the fridge fan noise. :ROFLMAO:
