Electrical cord zip ties
dogbalou
I am on a 6 month rv trip and noticed some cables hanging over the tandem axle wheels of our Avenue 32 rls slideout. When I went below I saw that the cords are held by mountable zip ties at 2 foot increments. About six have broken on the dinette slide, causing the snag, 3 or 4 have broken on the kitchen slide. They have only lasted a couple of years. Has anyone else had this problem, did you make an improvement to keep it from happening again?
Jwtsg
Good morning! Not exactly the same situation but offered for your consideration: On a previous TT, not 5er, similar cables had enough slack that we were able to move cables down to the bottom inside I beam frame ( same plane as where the corplast rested. And secure them w metal zip ties that were not rubbed by extension/retraction,,,.penetrated the eye beam w small drilled holes & #09 concrete reinforcing bar tie wire that we fastened the metal zip ties too,,,w wiring in split black pvc wiring loom under slide, worked for many years w only an occasional replacement on 1 or 2. Tie wire, zip ties, and duct tape are still some our best friends for quick fixes,,,hope this helps,,,enjoy your adventures, and safe travels,,,👍🌞🍀!
  • Like
Reactions: UFF
dogbalou
Thanks for the info. I replaced the zip ties yesterday. It was very easy, the hardest part was the hour drive to Home Depot from our remote boondocking spot. All of the ties broke right below the mounting eye, either fatiguing out from the wind or driving motion. I may go to a tie wire mount when I get back to my garage.
I agree. For now replacing with similar ties is a good 1st step. Especially if your on the road.
Keep an eye on it now that you are aware it's a potential issue.
If they fail again, you can upgrade to a more substantial tie down
Well sorry it happened. Zip ties are always handy to have around, rates right up there with duct tape. Hope you bought some extras.
