Hmmm, I thought the larger (width wise) awning was to the front. The smaller mounted to the slide.
The top part, that rolls in to the arm are all the same length, on the Solera. That is part of the reason I did it on the slide awning, I can reach the dropped part to zip it on. My main awning is too high to reach and zip on.
The size and layout or the 310RL is quite close to mine. The longer drop is ok, as you can walk it out and put stakes in the ground to hold it. Gives you extra room.
One of these would likely fit well. I went with the 10 foot height. 3ft or so rolls up in the waning, and works great.
The Solera Super Shade is a two-piece RV awning shade screen that can easily be installed for added shade and privacy. It solves the problem of today's larger RVs having patio awnings that are too high to reach when fully extended.Quick Facts: Two-piece front panel easily slides into the awning...
store.lci1.com
