Domestic 310 toilet issue
Wtrskier
We bought a 2022 32RLS new in July 2023. Since we started using it the toilet bowl would slowly fill with water after flushing. It was minimal so I was not overly concerned. Now we cannot leave water supply on overnight because it is filling too much.
Water trickles out of the flush holes after flushing.
Anyone else have this issue? We are currently in AZ until early April so taking it to dealer is not an option. Maybe a new flush pedal or a new vacuum breaker or water valve?
Thanks.
Hi folks, while I am no plumbing specialist, I would look at replacing the valve that is tied to the pedal that controls water flow.
In my mind, this has to be the issue as it is the last component in the water flow circuit before it enters the bowl.
Maybe the pedal is tied to the water valve by some sort of linkage that is out of adjustment?
Again, not a RV toilet expert, just giving you somethings to consider.
Best of Luck!
Fishfnatic
Best of Luck!
Thanks.
Wtrskier, we just got 2024 310 rl and my toilet will do same thing but not every time. I will keep an eye on it now
