My son and I just completed the installation of DC Lighting Dimmer Switches in my 2024 Delta 262RB:
Project
Replace OEM light On/Off light switches with On/Off/Dimmer switches
Objective
Have the ability to dim overhead lighting as desired
Products
JR Products 05-12315 - link (purchased from Alliance Parts)
JR Products 12275 - link (purchased from Alliance Parts)
Wago Connectors - link (2 and 3 position)
Installation Process
Alliance wired the light switches with both positive and negative wires present at the switch locations. This made the swap to dimmers very easy. Thank you Alliance
None.
Experience / Review
Working perfectly thus far and we don't anticipate any change. We've used these dimmers in past RVs with great results.
Pictures
Link to online gallery of all project pictures
Completed Project Video
N/A
Project
Objective
Products
- Determined which lighting circuits we wanted to dim. These were:
- Kitchen / Living Room
- Bedroom
- Slide: Over Recliners
- Slide: Over Dinette - Removed OEM switch.
- Verified with multimeter, which wire was 12v positive (vs load wire to light).
- Determined with multimeter, which wire was 12v negative (vs load negatives).
- Used existing Wago connectors and swapping to Wago connector swith more positions where needed, wired dimmers.
- Enlargened hold with sharp utility knife or Multi Tool, screwed into place and added cover.
- On/Off use is the same as the OEM switch.
- Dimming is done using the slider next to the switch.
- Potential future application is to add a second switch to the dimmer for certain circuits to manage On/Off from a second location (3-way circuit).
- Potential future application is to manage On/Off for certain circuits via Home Assistant.
None.
Experience / Review
Pictures
N/A
