Delta alliance 252RL, magnets on back of pantry drawers
Ron M
Just wondering if anyone out there has had the same problem with magnets attached to back of pantry drawers pulling magnet out screw and magnets attached from back wall ? We have 4 pantry drawers, and every one of them pulled magnet out of wall on first week of using our camper. Dry wall screw pulls out of azdel lamented wall ( no aluminium brace or other solid surface to mount magnet on ) , pretty bad construction. Anyone have this problem and what was the fix?
Jwtsg
Good morning Ron M,,,,There is a thread on pantry shelf issues @
  • Forums
  • Alliance RV General
  • Cabinetry and Trim in the sub forums that address similar shelf & cabinet magnet issues,,,,good info,,,some solutions,,,am certain other forum members will also weigh in,,,,good luck,,,am certain the issue is solvable,,,,good luck 👍🍀
Ox262
Oh yeah. Same here on my 262RB. We didn't even get through our first trip before they pulled out. I used the glue/toothpick trick to fill the hole and reinstall the magnet. I also added a small piece of duct tape to the flat metal plate so the magnet doesn't pull as strong and did the same thing on all the flat metal plates throughout the trailer.
Ron M
0x262 , thank you for responding, if Blue Compass doesn't fix, I'll probably do as you did. Thank you. ( not tying to point fingers at any company, but hopefully Alliance Delta looks in on these posts, and decides to do something better, so that you and I are the only ones who have had this problem).
