Delta 321BH 1 month observations
Goobersan
A couple items we've noticed in our first month owning a '24 321BH
—The 120v outlets seem to be on 1 gfci. I think splitting that to 2 (kitchen & Bunkhouse, bath & master)
—The 120v circuit is also on 1 breaker making it a challenge for winter camping w/ a Dehumidifier and a small space heater.
—Heating ductwork needs improvement. Master bedroom is 8-10° warmer than the rest of the camper. While the directional grills are nice a damper system would make it possible to balance the entire camper. This is why we're using a space heater in the Bunkhouse.
Love the camper so far. This being our first new rig we still have much to learn.
Bonesrh
Same. We’ve had ours since July but live at elevation in Colorado. The master bedroom is way warmer. The air to the bunk is cool so we run a second heater in there. I’m putting up rigid foam board around the bunkhouse and on the underside. I did add “dampers” to the master and bathroom vents, closed about 1/3. It helped airflow to the bunkhouse a little bit the air coming out is still not hot.
If you take the drawers out of the master bedroom, you can see the heater and check to see if the 3rd vent line to the bunkroom is pinched. mine was ran under the water lines and it pinches. you can try and run it better. I also taped up with HVAC duct tape (metal) the heater because it was bleeding lots of air into that void under the drawers. I also dampened the air to the kitchen and bathroom and master to move it more to the bunk. Made a large difference in the temp of the rear air and flow. I also supplement with a heater in the space and have been fine to keep it warm.
